allis crank
mf440
10-02-2007 06:02:39
I was woundering how far you can offset grind a wd45 crank befor you have to weld. how well do they handle the stress? thanks
pullerboy624
10-05-2007 14:27:13
 Re: allis crank in reply to mf440, 10-02-2007 06:02:39
AC i would like some pointers on what to do to my WD pulling tractor. I was told it has 90 hp but it still has the stock carb on it and it doesn't have a cam or strock.
mlpankey
10-03-2007 19:51:24
well you can go get aet of farmall rods with 1 3/4 rod journals and offset grind down to them should pick up some stroke. i cant remember the formula evey .100 thousandts adds some.
AC
10-04-2007 05:11:17
 Re: allis crank in reply to mlpankey, 10-03-2007 19:51:24
I am eventually going to put some billet aluminum Sharps rods (1.75" journal) on a '45 crank. Should give me a total of 5.125 stroke. Unless you want to buy the rods, 4.5" block and crank..? AC
mlpankey
10-05-2007 19:14:13
 Re: allis crank in reply to AC, 10-04-2007 05:11:17
ac you want have a rod failure with the international 1 3/4 rod the promblem will be the # 1 rod journal trying to support a 100 pounds of flywheel weight . thats where my 1 3/4 cranks broke before i backed up to a 2 inch journal
mlpankey
10-05-2007 19:17:15
 Re: allis crank in reply to mlpankey, 10-05-2007 19:14:13
sorry its the # 4 rod rournal #1 just has the pulley to support
