Pumpkin Pull in Fowlerville Michigan ?
Gearnut
10-01-2007 09:46:52
Hi some few posts back you guys were talking about a upcoming pull October 6th on the Munsell Farm on Mason Road. Then there was talk about a dead weight pull on Saturday, the 6th, and I'm a bit gray of the rest of it.
Is there a progressive weight sled pull on Sunday ? If so, what time ?
We would like to get some info on this event and if it is open to other pullers? 2 of us live within a hour's drive of Fowlerville. We both have tractors that pull in 5500, 6000, 6500 and what we would call div 2 or 3 (nothing spectacular)
Thanks
Mark Jonckheere
10-01-2007 10:17:35
 Re: Pumpkin Pull in Fowlerville Michigan ? in reply to Gearnut, 10-01-2007 09:46:52
yes the pull starts at noon on the 6th hundson mills pulling rules. no cut or road worn tires. dead wieght pull.I can fax a filer if needed.weight in time is 9-11
Gearnut
10-01-2007 12:17:10
 Re: Pumpkin Pull in Fowlerville Michigan ? in reply to Mark Jonckheere, 10-01-2007 10:17:35
Thank you for your reply. Just a couple questions, if you know.
Is the pull only saturday ? (no sunday pulling ?)
Can you tell me what weight classes ?
Hitch height ?
Any max tire size ?
If there is a web site with all the above info, perhaps you could include the link instead of answering all these questions. Sorry my fax machine is temp broke.
Thanks
Mark Jonckheere
10-01-2007 13:22:35
 Re: Pumpkin Pull in Fowlerville Michigan ? in reply to Gearnut, 10-01-2007 12:17:10
18 inch hitch , 2500,3500,4500,5500,6500. stock tires only and only Sat. are they pulling.more rules on the Hudson mills old power club site $10.00 fee and only one class per Tractor also 1957 or older
Gearnut
10-01-2007 15:26:24
 Re: Pumpkin Pull in Fowlerville Michigan ? in reply to Mark Jonckheere, 10-01-2007 13:22:35
Thank you very much ! No sense in bringing a later model Ford out to the pull, or a older IH with cut tires. I appreciate your time, I've directed this link to a bunch of east side (Michigan)pullers in case any are interested.
Here is a link to Hudson Mills, at least you can see the pulling apparatus, etc, although the link is way-outdated.
Link
