1466 Help
Redman kyle
10-01-2007 09:30:19
i jus got a 1466 pretty cheap the motor was bad has a rod out the side so i repowerd it with a Dt466 now and jus got it running 2day everything works great except when i put it in 1st gear low side or high and let off the clutch it acts like there is nothing there! all the other gears work fine and no unnormal nosies i changed the hyd fluid before we started it cuz it looked like milk prolly from sittin a long time i knw that it sat for 5yrs in a shed before i got it but when i drained the fluid i found what looked like little needle bareings? i not sure but maybe thats my prob guess i start tearing it down.. any ideas?
minnesota red
10-01-2007 19:27:12
 Re: 1466 Help in reply to Redman kyle, 10-01-2007 09:30:19
i would check the linkage to the speed shift under the dash between the clutch and brake pedals.
sounds like it is not shifting into first.
