Cylinder Pressure
jd b puller
09-24-2007 17:34:40
Has anyone ever measured actual cylinder pressure of a running engine? Would be fairly easy for a Deere guy with petcocks if he had the right tool, I'd think.
guido
11-09-2007 10:17:47
 Re: Cylinder Pressure in reply to jd b puller, 09-24-2007 17:34:40
Hey jd b puller
Here is the answer to your cylinder presure dynamics:
Pressure-volume is mesured with the piston position corresponding to 90 degrees BTDC as it moves up to 90 degrees ATDC on it's power stroke.
As the piston comes up pressures are 550# to 600# at start of injection air temperature at this time is 1000 degrees F + or - 100 degrees.
This of course vary with each engine. Once the fuel has been injected and starts to burn, peak cylinder pressures can ru 1800 to 2300 PSI, with temeratures between 3500 to 4000 degrees f.
GUIDO.
B-maniac
09-26-2007 11:27:53
If you take the ft./lbs. of torque at a specified rpm and divide it by 2 and then divide it again by 12 you should get pretty close to the actual "push" for each piston. I believe an inch/pound would be about as close as you are gonna get to what you want.
BushogPapa
09-26-2007 09:29:56
For some reason, it runs in my mind that the pressure increases by roughly a factor of 4
100 lbs compression= 400 lbs combustion pressure
Roughly..and that is assuming it is running at FULL throttle, with no obstruction to air flow..as the carb closes, the intake vacuum actually reduces the compression pressure, which is why it will slow down and idle..
Ron.
jd b puller
09-26-2007 10:13:14
 Re: Cylinder Pressure in reply to BushogPapa, 09-26-2007 09:29:56
Thanks Ron, I was thinking the same thing, but can't remember why that number rings a bell... Maybe I'll put a test port in a the front of the block this winter.
larry baker
09-25-2007 12:18:10
some of the answers and questions amaze me but i love the humor of G fever for sure
Paul Foltz
09-25-2007 15:52:45
 Re: Cylinder Pressure in reply to larry baker, 09-25-2007 12:18:10
What's so humorous about what g fever said? That is the way we check cylinder pressure in our 2 cylinders. Think about it!
G Fever
09-25-2007 02:20:20
Yea, park the tractor on a hill and screw the guage to the spark plug hole. Put the tractor in high gear and roll the tractor and then release the clutch to turn the engine over! Jump off and look at your reading.
G Fever
jd b puller
09-25-2007 05:58:25
 Re: Cylinder Pressure in reply to G Fever, 09-25-2007 02:20:20
No, Dingaling, not running speed, but actually running. (i.e. Combustion pressure)
G Fever
09-25-2007 15:47:48
 Re: Cylinder Pressure in reply to jd b puller, 09-25-2007 05:58:25
b puller
Forget that comment I made. I was thinking you wanted the cylinder pressure. But like you said, you maybe able to screw in a guage where the petcock goes so you can run the tractor.
jd b puller
09-25-2007 18:01:45
 Re: Cylinder Pressure in reply to G Fever, 09-25-2007 15:47:48
No Problem G Fever, I wasn't clear in the first statement. I want actual cylinder pressure with the engine running (SPARK PLUGS IN AND FIRING), not just at full RPM.
Hopefully someone has done this or wants to.
Richard Noggin
09-26-2007 06:33:22
 Re: Cylinder Pressure in reply to jd b puller, 09-25-2007 18:01:45
You Guy's crack me up. Think about this. Most not all Deere' have petcocks, also the pistons travel past the petcocks, so are you wanting pre-combustion pressure? All pressures are guidlines for worn rings. Pressures can be manipulated by Cam Timing. Last pressure is checked at Spark Plug, usually at top of Cylinder Bore on most all engines.
jd b puller
09-26-2007 07:52:09
 Re: Cylinder Pressure in reply to Richard Noggin, 09-26-2007 06:33:22
Richard, I don't have Petcocks in my tractor, but yep, you're right, they are back in the cylinder. Didn't think about that. How you gonna get combustion pressure without a spark plug? Kinda hard to ignite that fuel without the spark plug. Maybe one of the guys that's added them at the front of a Jerry's block, or Power Block.
I just want to know the psi associated with combustion.
Richard Noggin
09-25-2007 06:44:30
Oh, now that you made it clear, I don't know.
Richard Noggin
09-25-2007 05:32:42
How big of a hill will I need?
