460 diff lock
bm3501466
09-23-2007 17:26:16
Anyone have any ideas on a differential lock for a farmall 460. I dont want to build a limited slip, I mean a real diff lock like on a JD 4020 etc. This is for the dead weight pulls we have in the area where the biggest thing is getting the pan to even budge. Will parts from any other IH fit in the 460 rearend to make a good diff lock? Any fabrication ideas? use of some kind of clutch, magnet???? etc...
Redsm
09-23-2007 18:33:33
 Re: 460 diff lock in reply to bm3501466, 09-23-2007 17:26:16
set park brake a little
jd b puller
09-23-2007 17:40:03
Will a "Lincoln Locker" hold up?
whatintheworldiswrong
09-23-2007 18:53:45
 Re: 460 diff lock in reply to jd b puller, 09-23-2007 17:40:03
What is a lincoln locker?
randy hall
09-24-2007 13:06:52
 Re: 460 diff lock in reply to whatintheworldiswrong, 09-23-2007 18:53:45
a guy that i know that works on race cars calls that 'electro-lock'.
bm3501466
09-24-2007 07:43:16
Can you steer the tractor at all if you weld the differential?
jd b puller
09-24-2007 17:31:41
 Re: 460 diff lock in reply to bm3501466, 09-24-2007 07:43:16
until it gets light in the front end or it comes up.
jd b puller
09-23-2007 19:40:29
Like Drew said, Weld up the differential.
Miller makes fine products as well. "Miller Locker" sounds funny though.
Drew
09-23-2007 19:24:42
I would guess he means taking the "Lincoln" welder to the spider gears.
guido
11-09-2007 11:03:14
 Re: 460 diff lock in reply to Drew, 09-23-2007 19:24:42
HEY Drew
I think he means welding the spiders also.
I have done it for a friend of mine running a car in a 2 liter class on a road couses and he loves it! powering into the turns.
Guido.
