TROUT RUN PA PULL THIS WEEKEND
Fruitfarmer
09-20-2007 05:23:47
Junction US15 and PA973. Antique tractor pull, 1960 and older. 2500 through 10,000 lb. classes. FRIDAY night, Sept 21, 6pm, powder puff and double tree. Uncut and top cut tire classes, 3.5 mph. 3 classes per tractor. $5 per hook. SATURDAY Sept. 22, 11am, money pull. Uncut and top cut classes, 3.5 mph. 3 classes per tractor. $10 per hook. SUNDAY Sept23, 10am, regular pull. Uncut and top cut tire classes, 18 inch drawbar, 3.5 mph. Any cut tire class (wheelie bars), 6mph, 20 inch drawbar. All weight classes, $5 per hook, 3 classes per tractor. INFORMATION 570 435 2749, 570 435 3196, 570 435 5187.
Full Pull H
09-21-2007 09:44:47
 Re: TROUT RUN PA PULL THIS WEEKEND in reply to Fruitfarmer, 09-20-2007 05:23:47
What is the rpm limits in the classes? Do you make back cut tires pull in the any cut class?
Fruitfarmer
09-21-2007 15:18:25
 Re: TROUT RUN PA PULL THIS WEEKEND in reply to Full Pull H, 09-21-2007 09:44:47
On Saturday, for the money pull, the cut tire classes will include all types of cut tires. The speed limit will be 3.5mph for all weight classes. That day there will also be weight classes for tractors with uncut tires, again at 3mph.
Fruitfarmer
09-21-2007 15:10:53
RPM's are 10% over stock, but the primary control is the speed limit, either 3.5mph or 6mph. You are allowed 3 beeps of the speed limit horn. You can use any gear. Top cut tire tractors can enter either 3.5mph weight classes or 6mph weight classes, but not both for any one tractor. Front cut (or full cut) tire tractors can only pull in 6mph weight classes.
