Moline UB How Light??
RichB
09-18-2007 21:26:21
How light can you get a UB?? Is 4500 a possibility? Without a lot of custom aluminum parts.Thanks
LW
09-19-2007 18:38:29
 Re: Moline UB How Light?? in reply to RichB, 09-18-2007 21:26:21
I built one that pulls 4200 with a 180lb driver, and it will carry a 3X 65 lb weights on the nose,It run 14 mph in that class. Lots of work with 18.4X 38's we made it with steel wheels couldn't drive it with out nose weight. The aluminum wheels solved that problem. Then they wouldn't let the owner pull 4200 any more so now after all that work he has to pull 4500 up.
Mopower
09-19-2007 11:14:37
Much easier with a U. The older, the better. Without an aluminum or fiberglass tranny cover and oil pan on a UB, it'll be very tough. Just observed one around my neck of the woods pulling the last few years. No aluminum rims it was 4100-4200 or so bare bones. Lotta work to get there!
Dieselbear
09-19-2007 11:10:25
alum. oil pan, trans top, lite van rad., alum cylinder blocks,5 gal alum. fuel cell, other mis.small alum parts, alum. weight brackets, weld on axle plates. I have pressed steel rims now, hope I don't have to go to alum. rims. Hope I'm close. Mine is a UTU
MnM44
09-19-2007 04:23:28
4500 is possible but takes a lot of work. We changed the axle housings and axles in ours and ground and drilled the rearend housing pretty extensivly. Aluminum trans top and oil pan will help too.
RichB
09-19-2007 11:55:17
 Re: Moline UB How Light?? in reply to MnM44, 09-19-2007 04:23:28
Thanks for all the help guys,Guess I will cancel the idea,Was looking at the one on the photo ads.Nice tractor but need to be able to make 4500lb class.
Mopower
09-19-2007 11:59:04
 Re: Moline UB How Light?? in reply to RichB, 09-19-2007 11:55:17
Which one were you looking at? I saw two from Henderson's and both are excellent chassis and engines. you will be hard pressed to find a 4500# UB for sale but either of those would eb a giant head start.
