sherman
mike wc
09-18-2007 09:08:53
would like to buy sherman step down for wc
mlpankey
09-20-2007 14:46:23
 Re: sherman in reply to mike wc, 09-18-2007 09:08:53
i dont pull a wc i have a wd but i thought the advantage of the sherman box was it basically gave a selection of four more gears to select from. which still seams to be an advantage over the corn picker or rc rear. allis geared tractors to run 2.5 mile an hour in first gear when the rpms were raised the gearing went down to stay at 2.5 mile an hour
LWD
09-18-2007 20:24:48
you would like a 5tooth pinon gear better,or a `RC` rear end better. there is a better set up, but nobody is going to tell ya what it is.
AC
09-19-2007 05:22:12
 Re: sherman in reply to LWD, 09-18-2007 20:24:48
You arent gonna tell us ..cause you dont know?? or...too good to bestow your extensive knowledge on us..lol..just a j/k.. I know there have got to be Dodge Timkin truck gears out there somewhere that fit and alter the ratios...AC
mike wc
09-19-2007 05:01:23
I was told gear reduction of rc rear and step down was the same why would i like the rc set up better
LWD
09-19-2007 21:26:34
 Re: sherman in reply to mike wc, 09-19-2007 05:01:23
the `RC`pinon gear is a 5 tooth, but the 5 tooth pinon for the `WC`is stronger becouse it has a bearing support on the nose where as the `RC`s dont, they made the 5 tooth for the `WC` to use with a corn picker. go to the dealer and talk them in to giving you a blue-print for it, and get one made. I pull 6500 in second gear with 18.4s on good clay track, and spin out
mike wc
09-20-2007 05:49:31
 Re: sherman in reply to LWD, 09-19-2007 21:26:34
my question does the sherman have the same reduction as the rc rear or 5 pinion gear
AC
09-20-2007 08:00:58
 Re: sherman in reply to mike wc, 09-20-2007 05:49:31
Sherman should be approx 30 % up or down..AC
LWD
09-20-2007 21:19:35
 Re: sherman in reply to AC, 09-20-2007 08:00:58
I`m thinking the only place you will find a sherman is on a road grader,the M&W box is realy rare
