carb 706 question for chads
jpl
09-17-2007 17:05:07
chads, i have a 58 560 with a 291 eng, my carb walked off, i found one off 706 but it only has a #25 venturi in it, where can i get a #30 like the original carb had and put in the replacement carb. thanks for your help.
jpl
09-21-2007 10:02:04
 Re: carb 706 question for chads in reply to jpl, 09-17-2007 17:05:07
just got in off road, thank you chads for info, I;m kinda late but appreciate your help.
ChadS
09-18-2007 07:21:29
See if there is a listing for a 715 combine carb. Would be near identical to whats on the 706-856, but faces the carbs inlet to the rear of the tractor, so its a upgrade to the 560. 560 carbs are a twin port throttle body, which means they have two different locations to deliver fuel, the 706-856, and bout all the 15 series combines had triple port throttle bodies. Chad
jpl
09-18-2007 00:36:55
chads after checking my int books etc, i find the carb to be off a 460. so dont need a venturi. can order a 560 carb from yt site. int book shows 29 venturi for 560, mine had a #30 init. should run alright.
