U motor?????
MM U
09-17-2007 14:55:32
What would M5 jugs do for an U? what would all need to be replaced? Is there any thing bigger than a M5 that can be used other than the G crank and jugs?
Mopower
09-18-2007 04:35:49
 Re: U motor????? in reply to MM U, 09-17-2007 14:55:32
Use 4.81 pistons and get 363 cubes. It will bore to 1/8" +.060. Welters in MO sells Aluminum pistons. I used 1/8 hard gasket to make up for the piston height difference. Lubbock Gasket in TX will make gaskets from any material you want. With newer heads it will build great horsepower.
BCG
09-17-2007 18:49:23
The pistons are going to be a little tall. You eather need to take a little off the piston or space up the jugs. Not a lot of work and it makes a good runnin little motor.
BCG
ejr-IA,
09-17-2007 18:23:37
You would need M5 blocks and pistons and many choices of heads you would end up with a 336cid.With G stuff you would have a 403.
