Width of tires, SMTA
Don
05-26-2002 20:59:23
Hi, I pull a Farmall SMTA, I pulled against other tractors that are the same. We pull stock. My question is Mine has 13.6 tires new and they have 16.9 tires also new. Does the size really make that much difference? They been beating me by 15 ft. Thanks for the any information. Don
JCM
05-27-2002 11:24:47
 Re: Width of tires, SMTA in reply to Don, 05-26-2002 20:59:23
YOU MAY ALSO WANT TO CONSIDER PUTTING ON THE REAR ADJUSTABLE TYPE WHEEL/RIM LIKE OFF A 400 ETC.THIS WILL SPREAD YOUR TIRE SIDE WALLS AND GET MORE OF A EVEN TIRE CONTACT.I HAVE FOUND PUTTING A 15.5 ON THE NON ADJ. RIM GIVES YOU A DONUT EFFECT AND NOT MUCH OF A BENEFIT EITHER. ALSO YOU CAN GO AS LOW AS 14.9 TIRE ON TH ADJ. TYPE AND IT SPREADS OUT NICELY...SOMETHIN' TO THINK ABOUT.
54SMTA
05-27-2002 04:41:21
Yes, tire size does make somewhat of a difference. I have 15.5's on my SMTA. The wider the tire, the more traction you will get. Are you spinning out when you are stopped by the sled?
Along with the tires you need to make sure your tractor is weighted properly and you are in the right gear :)
Any questions, email me.
54
Don
05-27-2002 20:43:55
 Re: Re: Width of tires, SMTA in reply to 54SMTA, 05-27-2002 04:41:21
Hi, I had it weighted right, front end was just little lite. It did spin out, I pulled 2nd gear in 6500, 1st in 7500, 8500, 9500, had to use torque in 85 and 95. I do back off on the gas when necessary. I'm thinking about getting bigger tires, but I need rims and tires I think. Thanks for your info. Don
