john deere H puller
upperpinecreek
09-10-2007 19:10:09
does anyone out there know someone that has pulls JD model H that I could contact?
Ken 46
09-11-2007 14:04:03
 Re: john deere H puller in reply to upperpinecreek, 09-10-2007 19:10:09
Guess I will show my ignorance - How does "all the power go thru the camshaft" ??
Thanks - Ken
G Puller
09-12-2007 06:36:54
 Re: john deere H puller in reply to Ken 46, 09-11-2007 14:04:03
The rear end/tranny of the tractor is driven directly off of the camshaft gear. The other 2CYL JD models have the clutch on the end of the crankshaft. I don't know how much power I would push through that small camshaft??? Like others have said, if it's not too late, go with a JD B and have some fun with a lesser valued tractor.
JPatton
09-11-2007 18:05:37
Ken - I have never had one apart but my brother has one so I have been around his some. If you ever look closely at an H, you will notice the clutch is mounted higher than other 2 cylinder John Deere"s. This is because it is mounted to the cam. Also note that it turns backwards when compared to other John Deere two cylinders. The cam rotates in reverse because of the gear drive operation of the cam. This is true on any gear driven cam. John Deere, Chevy straight 6 cylinder engines, etc. Hope this helps.
J
Mopower
09-11-2007 14:11:20
The engine apparently drives through the cam and cam gear to the rear end. I have not had one apart, but have a junker in the weeds to open up.
Mopower
09-11-2007 07:43:02
I used to, then I bought a Moline. Good little tractor but they could use another 10 h.p. to compete in Farm Stock 2500#. They balance well!
jd b puller
09-10-2007 19:16:33
Nothing personal, but there's a lot better choices for lightweight pullers if you want a Deere. 420's and B's.
One thing to remember on the H is that all the power goes thru the camshaft...
Besides, the H's are neat little tractors and have a lot more value to them than a B.
