allis pistons
fusion9
09-10-2007 16:50:22
I have a wd 45, should I use lp pistons or wd flat top pistons to get cheap hp. I think lp give you 7.2 compresion ratio , but I dont know what wd pistons will give you. Thanks for the time
WARWAGON01
09-11-2007 11:23:22
 Re: allis pistons in reply to fusion9, 09-10-2007 16:50:22
IF IT IS STILL STOCK BORE I USED D-17 PISTONS IN MINE AND GAIN HP
mlpankey
09-10-2007 21:55:41
just find out what the compression height of a piston is then go to kieth blacks web site for piston click on calculators put in rod length stroke and compression height along with deck height and gasket thickness and make youre choice.
