MM 51 UTU
Tim Elliott
09-05-2007 15:03:31
I am in the process of restoring engine is in good shape recent new bearing etc. Would like to increase hp an cu in I have heard of many theories on heads cranks etc. I don't want to break the bank doing this,I'm at the stage of doing something and would like to any suggestions.
Mopower
09-06-2007 05:51:01
 Re: MM 51 UTU in reply to Tim Elliott, 09-05-2007 15:03:31
If you bolt on some M5 blocks and pistons, that would be cheap and about 70 horsepower. Heads would be good compression with the bigger bore. If you want more power, the sky is the limit. Use a G crank and overbore the M5 blocks for an easy 100 h.p. How much are you willing to spend? Our UB is 98 h.p. but some can be 728 cubes and 248 h.p. if you have dollars.
Ethan Berry - MI
517-726-0484
Satified Customer
09-06-2007 16:56:15
 Re: MM 51 UTU in reply to Mopower, 09-06-2007 05:51:01
Its only money! But think of all the "prize money" you're going to win. Ha Ha Just remember its all for the fun and the good people you pull with. But it does run real real good!!
Thanks Doug
