Shumway Pull
Jerry h
09-04-2007 04:52:02
There will be a two day pull in Shumway Il On Sept, 15th and Sept. 16th The pull on the 15th starts at 9:00 am with plow classes. The weight pull starts at1:00 Pm with weigh in starting at 12:00.
Sundays antique pull starts at1:00 pm with weigh in starting at 12:00 noon.
motorheadil
09-11-2007 01:11:33
 Re: Shumway Pull in reply to Jerry h, 09-04-2007 04:52:02
if i have a front weight bracket can i still pull plow class
1155puller
09-06-2007 18:55:35
Are you still running a 7000lb open class down there?
Jerry h
09-07-2007 04:58:34
 Re: Shumway Pull in reply to 1155puller, 09-06-2007 18:55:35
We have 6500lb and 7500lb wide open classes(trucks tractors???) This class is on Saturday. On Sunday we have a 6500 & 7000 open antique (open is open with turbos)
Farmall '47
09-04-2007 18:44:00
Will the antique classes be the same as in July?
comfortking
09-05-2007 05:00:48
 Re: Shumway Pull in reply to Farmall '47, 09-04-2007 18:44:00
Antique classes are the same, however note that we are pulling plow classes on Sat. morning at 9:00 am
Shawn W
09-04-2007 10:02:44
Hey,
what are the rules and classes for the plow classes. and which sled are you using. might have to come down for that.
thanks
Shawn
Jerry h
09-05-2007 14:42:05
 Re: Shumway Pull in reply to Shawn W, 09-04-2007 10:02:44
HeavenBound IL Sled Company
jerry h
09-05-2007 10:22:59
Plow classes are stock tractors only. You are allowed one set of rear weights no extra brackets or add on rear weights. You may run as much front weight as you wish, must be in front of radiator. We have 2,3,4,5 bottom and over. If need be we will run light and heavy classes for the 2,3 and four bottom. Depends on how many tractors need seperated.Plow pull starts Sat. at 9:00 am
