JD G compression ratio
JD Pullin'
08-31-2007 03:55:07
Question: Any ideas what the compression ratio would be for a G with a 8" stroke, .125 over, with a flat head (F486R) on it? Also, how high of a octane race fuel would you recommend?
skip33652
09-01-2007 05:18:23
 Re: JD G compression ratio in reply to JD Pullin', 08-31-2007 03:55:07
If you are using the styled g block and uncut A rods your compression ratio will probably be about 12 to 1 maybe 11 to 1. there is no gas that will not ping.it may run on alchohol. I have g with 8.25 " stroke +.125" m&w pistons styled head and block with rods that are shortened .375". it's compression ratio is just short of 8 to 1. it need s more than pump premium. runs great on 100 low lead aviation fuel.Paul
