case 401 weight
rustywrench1
08-30-2007 19:54:38
Hi, I�m looking at a 1955 Case 401 with Swartz wide front end and would like to know if anyone could till me how much work it would take to get it in the 5,500 lbs weight class?
Jim Johnson
09-02-2007 12:03:11
 Re: case 401 weight in reply to rustywrench1, 08-30-2007 19:54:38
You would only have to lose about 1100 LBS.
Jim
Lamont
08-31-2007 20:35:10
Change to pressed steel wheels, drop PTO and hydraulic chunk off of rear, build custom drawbar out of lighter material and you should be very close. 5500 lb. is very easy.
rustywrench1
09-02-2007 11:20:08
 Re: case 401 weight in reply to Lamont, 08-31-2007 20:35:10
But I need the PTO for dyno test.
Jim Johnson
09-02-2007 11:59:56
 Re: case 401 weight in reply to rustywrench1, 09-02-2007 11:20:08
Put it in to DYNO then take it out to pull.
Jim
