how much weight do aluminum rims save
shocker
08-30-2007 13:42:30
my tractor weights 5250 with me on it wondering if aluminum rims all the way around will get me into 4500. im useing 18/9/38 20inces wide rear. any ideas. oliver 770 tractor. thanks.
taz460
09-06-2007 02:52:21
 Re: how much weight do aluminum rims save in reply to shocker, 08-30-2007 13:42:30
A 20"x 38" aluminum rim will weight around 120# less than a steel equivalent.
Super 77 Puller
09-04-2007 08:38:42
I used to pull and 880 in the 4500 lbs class and i weigh 230 olivers can cut weight like no other tractor
just like cheatin
08-31-2007 08:12:30
Maybe he's got a v12 detriot in there. factory replacement isn't it? lol
Chances R
08-31-2007 06:57:56
This is only a guess on my part but with that tire size I would be suprised if aluminum wheels all the way around would save over 150 lbs. Only a guess!!!
shocker
08-30-2007 15:53:08
i weight 180 thats what it weights iv got presed steel wheels all the way around. got a motor in mine that prolly has alitte more horse than yours. So what do the aluminum weight compared to steel?
jd b puller
08-30-2007 19:52:34
 Re: how much weight do aluminum rims save in reply to shocker, 08-30-2007 15:53:08
I didn"t know HP had mass. What did you do, stuff a real pony under the hood???
"i weight 180 thats what it weights iv got presed steel wheels all the way around. ** got a motor in mine that prolly has alitte more horse than yours**. So what do the aluminum weight compared to steel?"
AC
08-31-2007 09:15:44
 Re: how much weight do aluminum rims save in reply to jd b puller, 08-30-2007 19:52:34
Naa, I'm startin to wonder if its a horses a$$ in the drivers seat?? JUST WONDERIN..AINT SAYIN FER SURE...
770
08-30-2007 14:14:58
My 770 with wide front, pressed steel and full hydraulics with the flat top fenders....4550 with me on the seat. You weigh what????
AC
08-30-2007 13:44:41
That 770 should be 4500 easy. What do you weigh, 700lbs?
