Tractor Pull at the Mason Dixon Fairgrounds in Delta, PA thi
davects
08-29-2007 19:17:31
We are having a pull in Delta Pa. at the Mason Dixon Fairgrounds on Sat. Sept. the 1st. Scales open at 8:00AM and the pull starts at 10:00. We'll be running two sleds. The one will start out with the 3,000 and work up, the second weill start with the 7,500 and work up. Antique from 3,000 through 12,500. Classics from 8,000 through 15,000. 5 MPH speed limit, 10% over RPMs. $15.00 per hook, 3 classes max. with each tractor. More if time permits. All procedes go to the Delta Volunteer Fire Dept. Trophies will be awarded for 1st. through 3rd. place in each class. Call Dave @410-459-0045 with questions. Hope to see you there.
