Turbo help
D B
05-23-2002 18:51:36
Im building a puller the engine is 330 cubes and is a 4cyl. I am allowed to run 3000 rpm and am going to use a Bosch pump putting out around 250cc of fuel. My concern is what turbo to use anyone have any suggestions. I dont know if it will spin a 3LM466 fast enough to work good any help is appreciated.
george
06-11-2002 21:23:55
 Re: Turbo help in reply to D B, 05-23-2002 18:51:36
I have went to a larger engine and have some smaller turbos available. Let me Know another MM puller
Dave N
05-26-2002 04:44:06
I ran a Cockshutt with a 339 cui motor and tried a 3LM466 even went to a smaller housing and it was hard to build over 15 LBS. of boost at that RPM.I have one used it only 1 time if you want one.I also ran a P-pump with 500 cc cap.I have a brand new turbo that I had for a spare that was a Switzer it built boost very easy even at 2500 RPM it would build 30 to 40 LB of boost if you are interested E-mail me This is a brand new never used turbo.I sold the tractor and dont need it any more. Dave
Roy
05-24-2002 19:07:56
Have a D17 Allis Chalmers with 262 BUDA with 3LM turbo and 370 head. With 30 pounds of boost I'm turning between 3500 to 4500 RPM.
post email
05-23-2002 20:07:05
If ya want help post your email address.
Otherwise check: www.turbofast.com
DB
05-24-2002 17:46:16
 Re: Re: Turbo help in reply to post email , 05-23-2002 20:07:05
No thanks on putting my email address on here. I didnt figure i could get any help. If i said it was a JD or IH it might be diffrent but a MM no this fourm is for the pro's. thanks for some help
