waukesha 320 stroking
yates
08-27-2007 16:43:00
offset grind what rods and pistons do guys use
A.P.
08-29-2007 09:42:06
 Re: waukesha 320 stroking in reply to yates, 08-27-2007 16:43:00
Another option would be to use 77 (not Super 77) rods with the 2.0" journal diameter for a stroke increase of close to 5/8" or use a Chrysler industrial six cylinder rod for an increase of around 1/2". As far as pictons go you should be able to find something off the shelf that may be close to the pin height you need, if not there are always semi-custom or custom pistons. What bore are you planning on running?
320
08-28-2007 14:19:17
c farmall rods get pistons made from c&p out of California, offset grind your crank you will pick up about .950 of stroke
