Oliver crank question
jp88
08-24-2007 09:29:19
Can an Oliver Super 88 crankshaft be ground offset and get very much more stroke.If so how much can be possibly gained and what rods would be the best to use?Thanks
A.P.
08-24-2007 21:08:41
 Re: Oliver crank question in reply to jp88, 08-24-2007 09:29:19
With a super 88 crank, the 2 7/16" diameter rod journals can be offset ground and reduced to the 2" 77 rod journal diameter gaining up to 7/16" total increase in the stroke. Some use other rods with either smaller or slightly larger (Chrysler 6 cylinder industrial rods) for larger or smaller increases in the overall stroke. An 88 crank would have a smaller increase due to the smaller starting rod journal diameter (2 1/4").
stroker88
08-24-2007 18:17:37
1/4" use 2" 77 rods
