found a 466
smdv806
08-23-2007 07:43:04
Got a DT 466 sitting around and a farmall 460. What do I need to put that motor in? I have heard that I will need a 666 back plate from a 312 diesel. Where can I find a back plate like that? Will any others work? What flywheel do I use? Are the motor mounts the same?
K.B.-826
08-24-2007 22:00:37
 Re: found a 466 in reply to smdv806, 08-23-2007 07:43:04
It's gonna take some work. 312 rear plate might bolt up, 312 from ealry 686 is also the same. You'll also have to see if a flywheel from a 666/686 312 will bolt up. The next problem you'll run into is the frame rails, the 466 front cover will be too wide to fit between them. A 312 front cover might be the answer, but once again, I don't know if it fits a 466. Check with salvage yards. The 466 front cover could be milled down to fit as well.
