Cams
Bob sanders
04-30-2001 01:51:04
Is there any HP advantage to using a JD 60 propane cam in a 60 gas tractor?.
Mike Aylward
04-30-2001 11:42:33
 Re: cams in reply to Bob sanders, 04-30-2001 01:51:04
Bob, they are the same cam, and the same as a late A. I put one of Robert's cams (Robert's Carburetor Repair) in my 60 and it really helped. I'd go that route if you want to change a cam. Hope this helps. Mike
Mike in Mo
04-30-2001 20:10:48
 Re: Re: cams in reply to Mike Aylward, 04-30-2001 11:42:33
Mike do you know what the seat to seat and .050 lift durations are on your cam? thanks, Mike
Mike Aylward
05-04-2001 17:32:34
 Re: Re: Re: cams in reply to Mike in Mo, 04-30-2001 20:10:48
Hi Mike. I don't know right off the top of my head but I have at least the seat to seat timing around here somewhere (if I can find it). I will try to find it and let you know. I do know there was more duration and was surprised at that, but I won't argue with the results. My dyno showed it. Mike
