moline heads?
lafngas
08-14-2007 12:58:15
I have a set of 4206 mm heads and two sets of 4232 heads that came of a g 1000 lp vista. thay ha+ve the big box ports does anyone make a intake for thes heads for my utu mm or do i have to make them what head is the best
Mopower
08-15-2007 08:01:32
 Re: moline heads? in reply to lafngas, 08-14-2007 12:58:15
What sort of intake are you looking for? It is hard to beat an LP style intake from 5-star through M670 on most engines. I have a couple. There is a guy (Peterson?) making the larger cast replacement intakes for big-cube pullers. 10A4232 would be far better than a 10A4206. Although the intake runners are of similar size, the square port to round runner makes for better air flow. The area around the valves is wider and shallower, making better combustion than the old narrow deep U-style chamber. If you decide against 10A4232, let us other MM guys fight over them!
