WC oil pressure
Tractor Rod
05-21-2002 04:17:21
Need some help with the oil pressure. I need to run minimum 50 pounds pressure. Put in rebuilt pump and only got 25 pounds. Any help will be appreciated. thanks Tractor Rod
Agco puller
05-24-2002 10:51:22
 Re: WC oil pressure in reply to Tractor Rod, 05-21-2002 04:17:21
Just curious why you you need 50psi minimum?
That about what a NHRA stocker motor needs
Are you 6000rpming it? I'd pay to see that!
Tractor Rod
05-25-2002 15:59:40
 Re: Re: WC oil pressure in reply to Agco puller, 05-24-2002 10:51:22
Hey AGCO we run our motors anywhere from 4700 to 5200 rpm's. This is why we need to get more oil pressure . Tractor Rod
TimC
05-21-2002 18:55:43
If the pump runs off the cam then 50 could cause premature wear on the came due to thrust.
20 psi is plenty if you are reading it on top of the motor.
Will
05-21-2002 08:52:23
That's about all the oil pressure they run.
