modified tractor rear end
cody jon
08-07-2007 14:02:12
Hi guys, i'm thinking of getting into tractor pulling and want to build a modified v-8 puller. trouble is, i dont know what to use for a rear end or transmission. this will be on a "low cost" budget so nothing fancy, just want something that will work. any thoughts are appreciated.
thanks
cody
mikes600
08-08-2007 17:29:11
 Re: modified tractor rear end in reply to cody jon, 08-07-2007 14:02:12
I use a MH44 rear end and trans, good set up for adding a drive shaft. Should be good for 800 plus HP.
dboll
08-08-2007 05:06:44
have saw v8's in about everything, f20/30, olivers, m farmall ect. cockshutt and massey are common but the massey gears are a little on the weak side, have been told cockshutt's are nearly in destructible.
