JD G fluttering
Jack
05-20-2002 14:55:25
I have a Pertronix positive ground electronic ignition in my 53 puller G and at higher rpm's it wants to flutter and sometimes cough.I reset the rocker arms to .020 intake and .022 on the exaust.I am using Autolite 3116's gapped on .041 thousanths.When pulled down it smoothes out.I have set the carb two rounds out on the load needle and gradually increased it but I can't seem to get it all out.I have 110 psi per cylinder.Any suggestions JD people?I have the wires with the actual wire in them too.Thanks,Jack(TN).
JDG
05-20-2002 20:25:03
 Re: JD G fluttering in reply to Jack, 05-20-2002 14:55:25
Check for weak valve springs
Gman
05-20-2002 18:28:45
Hey Jack try using 8mm carbon filled wires with that electronic ignition and see what happens.I run electronic ignition and a MSD box does fine. JUst an idea. Gman
JDGnut
05-21-2002 12:10:11
 Re: Re: JD G fluttering in reply to Gman, 05-20-2002 18:28:45
I had the same problem that plagued me for a year.. I changed to the wires that GMan listed and installed the Plug adapters with AC plugs, and no Problems since.. (I would look at the wires..) Good luck
JDGnut
JDG
05-20-2002 20:22:36
Check for weak valve springs!
rusty
05-21-2002 06:14:05
 Re: Re: Re: JD G fluttering in reply to JDG, 05-20-2002 20:22:36
Try throwing the Autolites away and using AC or buy the auto plug adaptors and using NGK plugs. They work much better for us.
Jack
05-21-2002 08:27:38
 Re: Re: Re: Re: JD G fluttering in reply to rusty, 05-21-2002 06:14:05
Tell me what kind of AC plug to use.I will try anything.I have no problems with NGK either.
Which ones??
05-21-2002 06:30:25
What do you like as far as the AC plugs?
Burns
rusty
05-21-2002 12:34:44
 Re: Re: Re: Re: Re: JD G fluttering in reply to Which ones??, 05-21-2002 06:30:25
Try a C 86 or C 87, they both work pretty good for us, with either Jacob's or MSD ignitions.
rusty
Justin
05-21-2002 16:01:39
 Re: Re: Re: Re: Re: Re: JD G fluttering in reply to rusty, 05-21-2002 12:34:44
I run C 86's in one of my G's and they seem to work really well. The other has C88L AC's and they work good too.
Jusitn
