loosing traction
stonerock
07-31-2007 14:02:16
hitch is 18 up 18 from center of axel 15.5 38 tires 9 lbs air 5500 class 2 100 lb weights pluss driver weights on back wheelie bars just hitting track front tires 30 up 6000 class 6 100 lb weights in back wheelie bars hitting track tractor is farmall m has plenty of power spins out 10 ft short of the other tractors can any one tell me what to do different thank you i am from centeral ohio
minnesota red
07-31-2007 20:13:44
 Re: loosing traction in reply to stonerock, 07-31-2007 14:02:16
put the weights on the front,wheelie bars are hitting the ground they are carrying the back of the tractor.
ideal run is front wheel 1 inch off the ground,so you will win more with the front on the ground vs the bars diggind into the ground.
1206 puller
07-31-2007 19:27:03
You could be loosing traction because of your air pressure. You may need more, like 13-15 psi depending on the track. If it's gravel lean towards 15, if its a hard clay, pull 13 psi. I hope this helps.
G deere
07-31-2007 18:57:44
Is it happening at every pull? Remember that if your pulling a shorter chain its better to move your weights towards the front of the tractor.
High Octane
07-31-2007 15:18:37
What size tires? Do you have a weight bar in front of the rear tires? Made a huge difference on my M with 600# on a belly bar none behind the rear axle.
