Results
terryjd
07-30-2007 21:37:09
Hi everybody thanks for your input. I was test puller in the 5500lb class so tried 2'nd gear. Spun all the way down the track. Took a second pull used 2'nd again spun down the track and spun out. In 6500lb class used 1'st gear, spun out at the end of the pull. Track was real loose stone dust. Got my butt kicked bad in both classes by most of the 77, 770, 880 Olivers. The speed they could run at the higher gears and rpm gave them a real advantage on that track. Next pull will be on clay so that will be 1'st gear for sure. The M usually does well on the harder pulling clay tracks then them loose tracks for some reason. If get butt kicked again then will know them green machines got fixed up real well over the winter and it will be time to go at the M and build it up for some more cubes, hp, whatever info I can find on here. Thanks again
