Radial vs Bias tires
nepuller
07-30-2007 17:40:16
What"s anybody"s experience with radial tires for pulling. I"ve heard they have more bite and that"s what I need - more traction. I realize some pulls don"t allow them. Thanks in advance for your suggestions
Super 77 puller
08-17-2007 06:34:33
 Re: Radial vs Bias tires in reply to nepuller, 07-30-2007 17:40:16
My experiance is that Radials do much better on a soft track where on a hard track the tread buckles and you dont do as good. But on a soft tacky track look out the radials are gonna clean house
NEPuller
08-17-2007 11:21:06
 Re: Radial vs Bias tires in reply to Super 77 puller, 08-17-2007 06:34:33
Hey thanks for your reply - that's just what I wanted to hear. I've got a set of radials and they're gonna be on the tractor before the next pull.
Case IH puller
07-30-2007 19:44:52
Well, before u look at tires, look at ur tire pressure. It took us a long time to get our air pressure figured out. We pull mainly 3500 sometimes 5,000, and we run 13 psi on a gravel track, and about 11 on a hard clay track. If u pull higher weight youll want more. Not sure about the tires. Hope this helps!
