Symco Thresheree Pull
WIPULLER
07-30-2007 08:15:53
So, what did we all think of this great event this year? In my opinion, they took this pull from one of the best around the state to one that I will not go back to next year. I have pulled there for the last 8 years, and I will continue to go see the displays, but I belive my Pulling tractor will stay home. I was not aware that 50rpm's made that big of a diference on a loose track. I'm wondering what everyone else has to say! I wounder if they checked that oliver pedal tractor later in the night.
Flyin Farmall
07-30-2007 21:18:10
 Re: Symco Thresheree Pull in reply to WIPULLER, 07-30-2007 08:15:53
Nobody was DQ"d for 50 rpm"s over.the guys that got dq"d were 100-500+ rpms over.Read the rules STOCK RPMS!! First you guys cry because the bigger tractors beat you,then you cry when we make everyone in the stock classes be stock?????
WIPULLER
07-31-2007 06:10:26
 Re: Symco Thresheree Pull in reply to Flyin Farmall, 07-30-2007 21:18:10
I was standing there watching and saw more than a handfull of guys get dq'd for being way less than 100 over. Im not complaining because I was not over, Im just woried that this great pull will be a lot smaller next year due to a lot of pissed off people.
Bryce
07-31-2007 06:16:16
 Re: Symco Thresheree Pull in reply to WIPULLER, 07-31-2007 06:10:26
Over is over,if you don"t enforce the rules why have them.If you want to run over on your rpm there are classes for that.For someone that did"nt get DQed you sure seem to be pretty upset.
WIPULLER
07-30-2007 10:47:19
Its not me that was one of the many that were disqualified. I just hate to see a local pull that attracts 300 tractors go to toilet because of something so retarded. I know they wanted to keep it fair but, it was a little extreme. If they have 100 less next year I would not be suprised.
want some
07-30-2007 10:06:19
cheese with that whine
mr X
08-02-2007 16:00:49
 Re: Symco Thresheree Pull in reply to want some, 07-30-2007 10:06:19
We got DQ'ed for 75 over and when we got it home we checked it without touching it and guess what 1600 on the nuts.
Bryce
08-05-2007 15:47:53
 Re: Symco Thresheree Pull in reply to mr X, 08-02-2007 16:00:49
If you are talking about an M Farmall then you were over anyway.1595,again over is over and if you will recall the winner was 100 under on his RPM.As was said before IT IS A STOCK CLASS! The same tach was used for all the tractors so it really does not matter what your tach says just as it does not matter what your scale says,what matters is what you are using that day at the pull.And whose nuts where you right on.P.S. I was probably the one who threw you out as I stood there proudly to run a FAIR pull.
