Compression ratio
John
05-20-2002 05:39:16
I need to find how to convert psi to a ratio. does anyone have an equation on how to find the ratio? Thanks,
John
Rich
05-23-2002 08:35:27
 Re: compression ratio in reply to John, 05-20-2002 05:39:16
These calculations are all technically correct, however, if the intake valve isn't closed at bottom dead center (and some engines do not), then the Gas Law calculated CR will be less than the mechanical CR.
phil
05-21-2002 11:05:17
John, here's yet another spin on the Ideal Gas Law. For an adiabatic process, the eqn is p1V1^k = p2V2^k. Then p2 = p1(V1/V2)^k. V1/V2 is the Comp Ratio C & k is a constant for air, 1.15. Rewrite, p2 = p1 C^1.15. p2 is absolute, to get gage pressure, subtract 14.7 psi. So P = 14.7 C^1.15 - 14.7
If you use the example C = 12, you will get 241psi pressure, close to Goldsburg's answer. And FYI, if you were to change the 1.15 to a "1", you will get about 160psi, close to Gman's answer. The 1.15 is what accounts for the compressive heating of the air. Additionally, T2/T1=(V1/V2)^0.15. If you grind thru this to find T2, you will find that Goldsburg's estimate of 810 degrees is in the ball park. If your compression ratio is lower, say your V1/V2 is only 5 or 6, then the temp drops about by 50 or 100 degrees. But, for this eqn, it doesn't matter, you don't need to have an estimate of the temperature.
G-MAN
05-20-2002 11:27:55
If you want to know the true compression ratio of your engine - without worrying about ambient temp, camshaft overlap, etc., the one way is to have the engine cc'ed. This involves filling the cylinder with a liquid to level full (usually accomplished using a plexiglass plate and a burrette) with the piston at bottom dead center, and also cc'ing the combustion chamber with valves installed in the same manner. Then raise the piston to TDC and repeat the procedure - there is no need to do the head again because that volume will not change, but you do need to add the chamber volume in. Simply divide the first total volume by the second total volume and there is your compression ratio. I believe that is how most performance engine builders determine it - even to the point of grinding material out of the combustion chambers on the higher ratioed cylinders to make them all equal. I mentioned the proper tools before, but now that I think about it, everything you need is readily available. I would use a large medical syringe to inject the fluid, as you will need to measure it as you put it in. I do believe you can get closer to figuring compression pressure with the 14.7 thing I mentioned than 2 points, as I once used it to estimate the compression of an engine we didn't have a spec for. We knew the compression ratio, and later when we found the compression spec, we found my estimation to be dead on - if the compression ratio were two points off, the compression could have been near 25 to 30 psi different. I have no doubt that Goldsburgs formula works for him, I simply don't like math that much.
Goldsburg
05-20-2002 14:59:56
 Re: Re: compression ratio in reply to G-MAN, 05-20-2002 11:27:55
GMan -
I am sorry that I may have offended you, but I was simply answering the question that John had asked: "Does anyone have an equation (for the conversion of PSI to a compression ratio)."
My issue with your method is that there is no science to back up the mathematical claim that you are making. As a matter of fact, I performed your calculation on the last engine that I built. The engine was 12.2 to 1 with 253 PSIG of cranking pressure. Your calculation yielded an "estimated" compression ratio of 17.4 to 1. My calculation yields an answer of 12.4 to 1. So it is really more than of a matter of it "working for me." It is reasonably accurate.
My guess is that he does not have "the engine" to CC, but maybe heard someone else's "cranking pressure" data and is trying to figure their compression ratio. If the engine parts were in hand, CC'ing would be the obvious answer.
I would say that if you don't have the parts in hand, I would rather know that the "guesstimation" that I am using is reasonably accurate, otherwise why guesstimate at all?
Regards,
Goldsburg
G-MAN
05-20-2002 15:23:28
 Re: Re: Re: compression ratio in reply to Goldsburg, 05-20-2002 14:59:56
Goldsburg, you didn't offend me at all - and I'm sorry if my post made you think you did. Like I said, I'm sure your formula works well for you, I just never did like algebra that much, and if I were going to determine c.r. I would cc the engine - I'm actually considering doing this in my G now just so I know exactly what I've got. I also said that my first method wasn't accurate, but I had seen it come pretty close - in several different instances. Obviously, the accuracy will depend on a lot of factors. You are obviously fairly knowledgeable in this area, so I have a question for you. How is it possible to get more than atmospheric pressure in a cylinder in a naturally aspirated engine? Is there some kind of ram effect involved here? Your calculations show 253 psi in a 12.2:1 engine - which would necessitate 20.2 psi of pressure in the cylinder with the piston at BDC, would it not? Maybe I'm missing something here, but I think that would have to be a tremendously volumetrically efficient engine to gain what basically amounts to 6 psi of boost pressure out of thin air. My high school math and science is way behind me, and I didn't pay that much attention then (obviously, lol) so please explain this to me.
Goldsburg
05-20-2002 19:52:28
 Re: Re: Re: Re: compression ratio in reply to G-MAN, 05-20-2002 15:23:28
GMan -
I am glad to see that you are paying attention (at least to a certain point)! If you would go back and re-read my posting with the formula and explanation, you will find that I had to make an educated guess at the cylinder temperatures after compression. You will find that the error in the "back-calculating" that you have done lies in the assumption of the T2 or temperature after compression. Again, I do not claim that my formula is "right on", but rather much closer than ignoring the temperature rise from compression. This is essentially what you are doing with the dividing by 14.7 PSIA.
You could also throw in accuracy (calibration) and the precision of the compression gauge, if you want to muddy the water yet still. I do not claim that the Ideal Gas Law will predict down to .00001 accuracy, but again simply to answer the question that John had asked.
If your "divide by 14.7PSIA" method is good enough for you, than I say "go for it." I just wanted to offer a different alternative, for people with above average math skills.
Highest Regards,
Goldsburg
G-MAN
05-20-2002 20:52:31
 Re: Re: Re: Re: Re: compression ratio in reply to Goldsburg, 05-20-2002 19:52:28
I have been puzzling over that ever since my last post, and I had came to the conclusion that the increase in pressure was due to the increase in temperature during compression - even without re-reading your post, so I guess I don't have to be a math major to understand your formula after all, it just requires common sense. Sometimes I can be a little slow on the uptake when my mind is on other things. I guess I also interpreted the original post differently than you did. My understanding was that he was either looking for the formula for determining c.r. in an engine during assembly - hence my reference to cc'ing, or looking for an approximation of compression ratio, such as for determining if an engine had had higher compression pistons installed. Anyway, your formula is very interesting and I will record it for possible use in the future - because I am actually pretty good at math - I just don't like it that much. I guess you only paid attention to my posts to a certain point, too, because I never said how good my math skills are. I'm still a little curious as to why I found my method to be fairly accurate in the cases I mentioned, unless the engine manufacturers didn't know what they were doing when they came up with their specifications. But I guess since my findings weren't backed up by the proper math, I must have been mistaken. It was also a brand new gauge in one instance, by the way.
ps - Isn't there some formula for determining the exact temperature of the gas/cylinder after compression, rather than resorting to an educated guess? I would think that a gas at a given temperature would rise in temperature to a predictable level based on the amount it is compressed, especially if you know it's original temperature and the pressure after compression. And what do you base your educated guess on? Wouldn't it be possible to just play with the temperature part of the equation until the formula produced the correct answer? Oh well, I'm not going to think about it anymore - I'm obviously not mentally equipped for such deep contemplation. Have a nice day.
G Taylor
05-20-2002 23:07:42
 Re: Re: Re: Re: Re: Re: compression ratio in reply to G-MAN, 05-20-2002 20:52:31
The heating effect on pressure varies with cranking rpm, faster the cranking the higher the temp. Less time to leak down past the rings as well. The rate of heat absorbsion from the combustion chamber gases to head/cylinder walls & piston varies with volume to wall area ratio. A 53 cubic inch cylinder will cool much faster than a 235.5 cubic inch cylinder, all other factors identical. Mechaical compression ratio compared to cranking pressure will indicate the degree of valve overlap & percent cylinder fill at that particular rpm.
Don't forget the volume of the head gasket
05-20-2002 11:38:19
burns
G-MAN
05-20-2002 13:21:30
 Re: Re: Re: compression ratio in reply to Don't forget the volume of the head gasket, 05-20-2002 11:38:19
I knew someone would mention that - trouble is, it's hard to get the volume of the head gasket when it is compressed, lol. I think if anyone is going to that extreme, they're probably sharp enough not to need my amatuer advice. I also later thought that you should try to cc the engine with it running, as the oil film between the crank journal and the bearing could push the piston up more and cause a change. And if you believe that, I've got this real nice bridge for sale...
Goldsburg
05-20-2002 09:23:04
John -
GMan's approximation will get you "in the ballpark" with a tolerance of +/- 2 comp ratio points. If you want to get much closer, than you have to use the Ideal Gas law.
I have taken the Ideal Gas Law and converted it to a form that we can use here.
PV=nRT; and we are looking at V1 and V2; Remember that a compression ratio is:
(Swept volume + fixed volume) / fixed volume
So we will need:
(V1 + V2)/ V2;
using an algebraic manipulation of the Ideal Gas Law equation from above, the comp ratio is defined as:
((T1/P1) + (T2/P2)) / (T2/P2)
Now we have to make some assumptions about the temperatures and remember that all of the variables have to be in "Absolute" units. This means that temperatures will be in degrees Rankine (deg F + 460) and the pressures (PSI gage) will have 14.7 added to them.
Let's say that you want to find the cylinder PSI which corresponds to 12 to 1 comp ratio. The ambient temperature (T1) is 75 deg F. Atmoshperic pressure (P1) is 14.7 PSIA. You know that your temperature after compression is going to be much higher than prior to compression (kinda like a diesel). We will guess that the temperature of the fuel/air after compression (T2) is 350 degress F. That makes T2= 810 degrees Rankine.
To summarize what we know:
(V1 + V2) / V2 (comp ratio) = 12
T1= 535 deg R (75 deg F)
P1= 14.7 PSIA
T2 (assumed)= 810 deg R (350 deg F)
P2= ?????
Using our equation:
Comp Ratio = ((T1/P1) + (T2/P2)) / (T2/P2)
solving for P2...
P2= ((comp ratio -1)*T2*P1)/T1= (11*810*14.7) / 535
P2 = 244.8 PSIA
or approximately 230 PSI on your compression tester.
I know that this is a lot to digest, but if you use the last equation shown that defines P2, then you will be able to predict the cylinder pressure based upon a compression ratio within limits of the Ideal Gas Law. Just remember that temperatures will have to be in Rankine (deg F +460) and pressures will have to be absolute (PSI gage + 14.7) and that your answer will be in absolute PSI. You should also keep in mind that this will be a theoretical pressure and that it may be influenced by camshaft timing, cylinder head geometry, intake manifolding, and carburetion. That equation again is:
P2=((comp ratio - 1)*T2*P1)/T1
If you have any questions, please feel free to email me.
Regards,
Goldsburg
G-MAN
05-20-2002 07:45:39
I know it's nowhere near completely accurate, but you can get a ballpark figure on comp ratio by dividing compression pressure by 14.7 - atmospheric pressure at seal level. This is going to differ based on altitude, volumetric efficiency of the engine, etc etc etc, but I have checked it occasionally by dividing the specified compression pressure by the comp ratio of an engine I know the ratio of, and it will come out fairly close. Like I said, you won't be able to figure it out down to the tenth of a point, but you can get reasonably close. The only way to accurately find compression ratio is to cc the engine - which can be a fairly time-consuming process, unless you already have the tools to do it.
