Oliver 880
Jeremys108
07-27-2007 11:05:10
Is it possible to get a Oliver 880 light enough to pull in the 4500lb. class?
Oak
07-29-2007 13:11:37
 Re: Oliver 880 in reply to Jeremys108, 07-27-2007 11:05:10
Done easy- I still have PTO and Hydralics, Stock Seat and Fenders on mine and can add 2 70lb weights on it to make 4500lb with 66 front, press steel all around
Fruitfarmer
07-27-2007 16:59:19
Pressed steel wheels alone will do it. Use 5.50 x 16 tires up front and some worn 15.5 x 38 in the rear. Your own weight is a contributing factor. 170 to 180 pounds is probably the limit, depending on the scales. Use 10w-30 motor oil in the transmission as the owner's manual calls for.
Jak
07-27-2007 14:23:49
Yes sir you can but it needs pressed steel wheels and maybe fenders removed.You won't have much moveable weight to play with unless you remove the live pto off the back.
