horsepower per cubic inch
Mopower
07-25-2007 06:35:16
I assume I-H being the highest and Deere being the least horsepower per cubic inch based on rpm and combustion chamber design. Most stock gasoline Molines would run .18 to .25 h.p. per cubic inch with .25-.30 on some good propane power units. With the years of engine building experience on this discussion board, can any of you tell me an acceptable horsepower per cubic inch level for various high compression pulling tractors running 10-20% over rpm?
mlpankey
07-25-2007 22:18:13
 Re: horsepower per cubic inch in reply to Mopower, 07-25-2007 06:35:16
build for torque . torque is a must at low rpms . and remember most dynos show that torque and horsepower cross over at 5500 rpms .this is how diesels show more torque than horsepower they were never built to turn 5500 rpms
minnesota red
07-26-2007 18:39:23
 Re: horsepower per cubic inch in reply to mlpankey, 07-25-2007 22:18:13
5656 i believe is the rpm that hp and torque are equal.and all dynos measure torque and convert it to hp.
jd b puller
07-25-2007 19:20:46
MoPower, people talk about this from time to time. Really useful when talking about building a SBC or Ferd, not too sensible when dealing with engines that run at considerably different RPM"s.
Consider the really simple equation...
Power = (Cubic inches)*RPM
Then just compare, and you"ll see that there is a general ratio between tractors. If people on here could input their Cubes, HP and RPM, you"ll find on the ones that are "Built", the ratio should be similar. Likewise, if you look in the data books for stock tractors of a similar year, it works out pretty close...
If you look at some stock Deere"s (sorry, that"s the only engines I know bore/stroke/RPM and HP of.... The ratio of RPM*Cubes is about 10000:1 vs. HP. On a built engine, it seems to run closer to 5000:1 --> 6000:1
B (26HP) -- 189in * 1375RPM = 261016 -- 10039:1
A (35HP) -- 321in * 1115RPM = 357621 -- 10218:1
G (47HP??) -421in * 1115RPM = 459944 -- 10221:1
Would be interesting to see if it really holds true with the other models.
One puller described his 600 inch SuperM as having 200HP @10% over == 600 in* 1760RPM = 1056000
-- so 1056000/200 = 5280:1
Thanks Guys
07-26-2007 05:18:04
 Re: horsepower per cubic inch in reply to jd b puller, 07-25-2007 19:20:46
Yeah, torque is what is desired. That's why a Deere or MM can hang with smaller engines making bigger horsepower. Curiosity was killing me to see how different companies compared. Oliver has to be up there too. Thanks for the info. It is very useful and more practical for pulling logic.
p.s. HD220 LP power unit makes 66 h.p. at 1900.
HD800 can make up to 250 h.p. Much better than the old MM U & Z gas tractors like a 283 making 46 h.p. or a 206 making 33 h.p.
Jack a
07-26-2007 09:47:56
 Re: horsepower per cubic inch in reply to Thanks Guys, 07-26-2007 05:18:04
Maybe if horsed up but out of the box I have never seen a 60 Deere come close to a WD45. 321 vs 226. But I'm talking more about field performance anyhow.
AC
07-26-2007 06:10:26
Let it go Louie, let it go....Yer not gonne convert the world to Mother Molime 1 person at a time no matter how hard you try..
case ih
07-27-2007 04:15:55
 Re: horsepower per cubic inch in reply to AC, 07-26-2007 06:10:26
A.C.and mopower you must have a stuffed up nose with it stuck up everyones butt!
AC
07-27-2007 04:19:58
 Re: horsepower per cubic inch in reply to case ih, 07-27-2007 04:15:55
welllll , its not up yours so what are you worried about?
case ih
07-27-2007 17:20:26
 Re: horsepower per cubic inch in reply to AC, 07-27-2007 04:19:58
You're right.Who knows where it has been,probably around you,re fella's
AC
07-28-2007 04:34:54
 Re: horsepower per cubic inch in reply to case ih, 07-27-2007 17:20:26
WOW, you"re stinging me soo badly, especially with your lousy typing and grammer.
Mopower
07-26-2007 11:12:15
Who put their who-who-dilly in your cha-cha?
6077
07-27-2007 19:36:40
 Re: horsepower per cubic inch in reply to Mopower, 07-26-2007 11:12:15
What The heck kinda talk is that. Fella Talk or something
AC
07-29-2007 13:50:04
 Re: horsepower per cubic inch in reply to 6077, 07-27-2007 19:36:40
No, I think its his polite way of asking "Who's shoving a stick up your a$$" because I havent returned anyone's calls as of lately...
Mopower
07-30-2007 05:37:56
 Re: horsepower per cubic inch in reply to AC, 07-29-2007 13:50:04
No worries AC. I guess if someone might know what "fella talk" sounds like, it might be this fella.
Mopower
07-26-2007 07:31:03
Looks, it's alive! I have my orders from the MM mother ship. Resistance is futile.
