allis styled wc engine swap??
t.r.y.
07-22-2007 12:31:30
Hello I got a wc with a pretty bad stock motor. Looking to swap with a d17 or wd, wd45 engine. Will all or any of these work in this tractor? thanks in advance
mlpankey
07-22-2007 16:44:22
 Re: allis styled wc engine swap?? in reply to t.r.y., 07-22-2007 12:31:30
yeahp even an e gleaner will fit
t.r.y.
07-22-2007 16:47:52
 Re: allis styled wc engine swap?? in reply to mlpankey, 07-22-2007 16:44:22
any body know where I can find a long block of a d17 wd45 or e gleanor. I take it i can use dist. gover, valve cover oil pan and all the other stuff on those motors too? thanks also whats a good carb to run thanks
mlpankey
07-22-2007 22:18:58
 Re: allis styled wc engine swap?? in reply to t.r.y., 07-22-2007 16:47:52
carb for pulling either a holley from a 195 allis or from a ford if motor is small .if big cubes a usx20 marvel will feed the beast
