need more
small time pull
07-20-2007 18:38:02
power out of my tractor engine. it still has the standard fractory bore pistions. what is a cheap quick way to get a little more power out of the old gal?
The Dukester
07-22-2007 05:52:20
 Re: need more in reply to small time puller, 07-20-2007 18:38:02
Make it run perfect with a overhaul, not sparing anything to make it as good as new and then tune it to perfection. If it'll spin it's wheels on any surface in low gear you should have a chance unless you're trying to pull "with the pro's".
Hoss in Maine
07-21-2007 08:14:25
use high test
jd b puller
07-21-2007 15:57:38
 Re: need more in reply to Hoss in Maine, 07-21-2007 08:14:25
One of the most popular misconceptions out there... Octane doesn't have more power or make power, it lets you make power. Octane is RESISTANCE to burning, not BTU's/lb(or gallon).
It'd help if we knew what kind of motor you're playing with. Compression is the cheapest HP you can get. Minus all the things that factor into it, there's a direct link in the equation between BTU's in and out to Compression ratio.
More Info
07-21-2007 01:22:18
Gas, Diesel, what make, model, what do you use it for? Or are you fishing?
