Tubeless mounting
Jim Johnson
07-20-2007 07:36:35
A friend is trying to mount his pulling tires without tubes, one aired up and is holding air just fine but the other has a slow leak around the bead, he used silicon around the bead and it still won"t seal completely.
He dosen"t have a computer so he wanted me to ask if there "s something else that would work better than silicon.
Thanks Jim
sflem849
07-20-2007 19:10:15
 Re: Tubeless mounting in reply to Jim Johnson, 07-20-2007 07:36:35
Why would one want to do this? (I'm new to pulling)
BUDD
07-21-2007 05:04:11
 Re: Tubeless mounting in reply to sflem849, 07-20-2007 19:10:15
To get the tractor lighter. the tubes are about 20 lbs each.
BUDD
5 Star General
07-20-2007 15:44:46
Check bead If bad forget it.
Jim Johnson
07-20-2007 18:10:41
 Re: Tubeless mounting in reply to 5 Star General, 07-20-2007 15:44:46
Talked to him today and he said it was holding air now. Thanks
superh
07-20-2007 14:28:18
Tech beadlocker. 2 sets and no problems.
ChadS
07-20-2007 07:44:33
Windshield sealer worked for me. Chad
TDM
07-20-2007 10:58:58
 Re: Tubeless mounting in reply to ChadS, 07-20-2007 07:44:33
There's a bead sealer made for tires, seen it on smaller tires but not the big ones. I don't know if you can get it at parts store, but tire dealer should have it.
