IH RD injection pump
ihbrad
07-16-2007 19:16:40
Is anyone running an RD pump for pulling, or know of someone. I have one on my 806 and I am about at wits end because I can't seem to get enough fuel out of it to make more power. I am looking to have some conversation on the subject.
Thanks!
ihbrad
07-17-2007 18:26:36
 Re: IH RD injection pump in reply to ihbrad, 07-16-2007 19:16:40
Thanks for the feedback. I have been through the Roosamaster thing with my 1206 big pump, big injectors and big turbo,runs real good. I also have a 806 with the same setup only with the RD pump. The big RD was used on early 817 IH engines and but I am getting maybe 200HP out of it.
Buzzman72
07-17-2007 15:52:55
If you're referring to IH Red Diamond engines, they were primarily gas [mighta coulda got a propane version way back when] and carbureted...so I don't think there IS such a thing as an injection pump for one, at least not as they came from the factory.
I Know
07-17-2007 16:10:48
 Re: IH RD injection pump in reply to Buzzman72, 07-17-2007 15:52:55
RD is the name of the injection pump used on early 806 IH D361 diesel engines.They were replaced by Roosa-masters.
Buzzman72
07-19-2007 15:39:09
 Re: IH RD injection pump in reply to I Know, 07-17-2007 16:10:48
Sorry...other than my years at the Blue Oval dealership, I'm not too deisel-literate.
856puller
07-17-2007 08:00:08
I dont know anything about a "rd" pump Steve at st joe diesel helped us a lot with our system a rosamaster with a 450 head and booster pump big tips and lines. you may not need that mutch fuel if you dont have a turbo or the cubes. if it is a puller only you might as well build it big now so you will have it when you want to move up later. an in line would be better yet
