JD A Carb..Makeing it into a G carb?
SB
05-18-2002 21:49:08
I was going to get a big nut G carb for my A but i was talking to a guy and he decided that it would be cheaper and closer if we just bored out the holes. is this possible and if so what are the specs on the holes and what not. what else can i do for more horse w/out getting in the engine and no tblowing the big bucks. Thanks Shohn
SEAMO
05-21-2002 19:14:36
 Re: JD A Carb..Makeing it into a G carb? in reply to SB, 05-18-2002 21:49:08
Sorry I made a mistake we are not suppose to sell our service on this forum. e-mail me I wont do it again. I am new at this computer game.Earl Seamands
Dale W.
05-21-2002 00:05:13
The phone number for Robert's Carburetor Repair is 712-262-5311. Web site is:www.robertscarbrepair.com e-mail is: [email protected]
Hope this helps you, but I agree with the person that told you that a dltx 71 runs as well on a stock G as a dltx 51, if you are burning gasoline instead of kerosene or distilate.
burns
05-20-2002 08:27:49
The bigger question is do you feel you "NEED" the extra volume. The late A 71's work well on the A's and G's and they are more reasonable in price compared to the 51's
G-MAN
05-20-2002 07:53:14
Call Robert's Carburetor Repair - he's going to modify the A carb that was on my G to work on it. He claims it will be able to support 800 cubic inches when he's done, although I won't be anywhere near that. He seems very knowledgeable and helpful. Just my two cents. Plus the waiting list is shorter for performance carbs - he told me it would take about a month, rather than the 3 to 4 that stock rebuilds take.
SB... number Gman
05-20-2002 18:59:25
 Re: Re: JD A Carb..Makeing it into a G carb? in reply to G-MAN, 05-20-2002 07:53:14
What is his number? thanks
G-MAN
05-20-2002 19:43:56
 Re: Re: Re: JD A Carb..Makeing it into a G carb? in reply to SB... number Gman, 05-20-2002 18:59:25
I don't have his number here handy, but he has a website that has it. Just search for Robert's Carburetor Repair and you should find it, no problem. I spoke to Robert himself, and he sure sold me. He's very helpful and courteous, and will take the time to answer all your questions.
Seamo
05-19-2002 16:31:56
Send it to me I do it all the time.
SB
05-19-2002 18:34:36
 Re: Re: JD A Carb..Makeing it into a G carb? in reply to Seamo, 05-19-2002 16:31:56
where you at? there is a guy here that can but he just needs to know what sizes, what do you use?
Seamo
05-20-2002 18:06:41
 Re: Re: Re: JD A Carb..Makeing it into a G carb? in reply to SB, 05-19-2002 18:34:36
SB. I have no problem with the fact you want to do the carb yourself rather than pay me or Roberts to do your carb. All you have to do is get a # 51 carb and take it apart. Get a # 71 carb and take it apart and compare them. Start to cut. I ruined one before I got It figured out. I didnt think that was too high of a price to pay to learn.You can make both of those carbs bigger to run 800 plus cubes without a fuel pump.Do one and let us know what you think is a fair price to pay to have one done. How many hours? Earl
Cost??
05-20-2002 18:50:44
 Re: Re: Re: Re: JD A Carb..Makeing it into a G carb? in reply to Seamo, 05-20-2002 18:06:41
So tell us all what you charge to do one of these carbs?????
Scott Boehler
05-20-2002 19:06:08
 Re: Re: Re: Re: Re: JD A Carb..Makeing it into a G carb? in reply to Cost??, 05-20-2002 18:50:44
Seamo does the carb on my tractor and it works perfect. The performance will out weigh the cost. Scott Boehler
Cost???
05-21-2002 05:09:54
 Re: Re: Re: Re: Re: Re: JD A Carb..Makeing it into a G carb? in reply to Scott Boehler, 05-20-2002 19:06:08
What is the cost for him to do a carburetor??
Deere Puller
05-20-2002 06:16:22
He's probably trying to make a buck to cover some of his 'hobby' costs, just like many of us do. If that's what you want to do, take your measurements first (pre-machine) & compare when you get it back. Make sure to use wire gauges to measure idle circuit, etc. Then next time, you'll be all set! Knowledge is valuable!
