Tire Sizes
Welding man
07-15-2007 11:13:36
Does anyone know of a book that lists the original tire sizes that came on the various makes and series of tractors? Our antique tractor club has a tire rule and we don't always know what size tire came on a given tractor. Any help would be appreciated. Thanks Weldin man
Last Place
07-16-2007 19:42:16
 Re: Tire Sizes in reply to Welding man, 07-15-2007 11:13:36
Just put a limit on tire size and through the classes and that makes it fair for all tractors and or the wheels. Make the puller provide the proof for wheel type and size from their owners manual.
07-15-2007 14:30:05
 Re: Tire Sizes in reply to Farmall MD, 07-15-2007 11:23:52
Keep in mind that the data there is not 100%. I have looked at the entire Massey Ferguson line for 1976 comparing it to the machinery guide that they provided. The tire sizes listed are only sizes that were submitted. The model 2805 came with 4 options, they only have one listed which is not the standard according to the book. It also depends on if it was fitted with the long or entended axles. I see this with all of the models.
Weldin man
07-15-2007 16:26:01
 Re: Tire Sizes in reply to [email protected], 07-15-2007 14:30:05
I agree Tractor Data.com is no where near complete enough for what I need and it's just too expensive to buy manuals for all the different tractors that pull. Thanks Again
MN Dave
07-15-2007 20:11:27
 Re: Tire Sizes in reply to Weldin man, 07-15-2007 16:26:01
I pull a IH 400 and I've seen different STOCK tire sizes listed for it, so I can't tell what is stock for my own tractor. Different years, publications will list different tires.
Most pulls do a max tire size for the different weights (which can be argued about when making the rules). Sometimes a max tire square inch on ground will make allowances for some of the odd sized tires out there, especially in the smaller tractors, 24, 26, 28 or even 38 inch diameter pulling in the same class.
Drew
07-15-2007 20:08:08
Why cant your club make it easy on yourselves and make a tire size limit for a class?? That is a lot more fair than one tractor being allowed to run a larger tire than another tractor in the same class just because the factory offered it as an option.
