First Pull
LinemanFarmer
07-09-2007 19:18:45
Hi, I have finished restoring my Farmall M, putting the Super M kit in the engine, one back tire is brand new with 23 degrees and an old tire 1/3 to 1/2 tread left with 45 degrees bars, have not weights on, and I have my first oppertunity to a tractor pull this coming weekend. I have no idea what Im doing, so if you guys could walk me through what I aught to do durning and before the pull, what gear and hitch hight? Im getting pretty excited for this show/pull!
Thanks DEREK
Jeff Oliver
07-10-2007 18:25:30
 Re: First Pull in reply to LinemanFarmer, 07-09-2007 19:18:45
If this is your first pull I suggest doing a Farm Stock pull and see what the tractor will do first. If you have wheel weights and know about what class you want to start in weight up to it or down whichever you need to do. Check with whoever puts the pull on for details like hitch height and things like that.
Most farm Stock classes have a 1st gear rule but some are MPH. I personally would pull in 1st and see if the front end comes up and such. If it does then you are going ot need to put a weight bracket on or something and stop that.
Most important thing to remember is have FUN!!! Watch what other people pulling your type tractor are doing and learn from that.
