Electronic ignition
LG
07-09-2007 08:54:07
Has anybody bought electronic ignition from Denny's carb shop. Just wondering if it's worth it for the old H.
LG
07-10-2007 03:13:56
 Re: Electronic ignition in reply to LG, 07-09-2007 08:54:07
Thanks I think I'll give it a try.
bm3501466
07-09-2007 14:15:33
Don't listen to anyone who says electronic ignition isn't worth it. It is great. Your tractor will start regardless of the weather. lol I have found that it is easier to maintain a tractor with electronic ignition because you don't have to worry about replacing points and condensors and adjusting them. Electronic ignition doesn't provide HP boost, but it does allow for better response which can make a huge difference when the tractor is being really lugged. You can even gap your plugs a little more. Remember though you need to have a ballast resistor somewhere whether it be already in your coil or in line so you don't burn up the ignition module. The other good thing about pertronix is that they have a good warranty, but remember to keep your points because electronic ignition is another good thing, but it can fail as well.
lg
07-09-2007 12:04:51
denny's has a 55,000 volt coil, the ignition module, and a set of 8mm plug wires for $150. does this sound like a good deal. thanks
Jak
07-09-2007 10:11:10
I put the Pertronix in all mine that I've had and love em.I got my best deal from CBS Performance on CO.Look up CBSperformance.com to get thier 1-800 number and see if they are less expensive than Denny's.
Hoss in Maine
07-09-2007 15:45:31
 Re: Electronic ignition in reply to Jak, 07-09-2007 10:11:10
Hey lg, I just put the electronic dist. from Dennys in an M i reworked this winter and love it. Now we can run it a lot richer with hotter plugs and 045 gap to fire the mix. Id recomend on any tractor cept one with a mag. later Hoss
