stroking a 466
DT466
07-08-2007 18:30:27
Can I take the pistons and sleeves out of the newer navistar 466 and put them in my old 466 to make a 530??? Any help is appreciated
minnesota red
07-08-2007 19:48:20
 Re: stroking a 466 in reply to DT466, 07-08-2007 18:30:27
i believe the wrist pin is bigger on the 530.
get some case 504 sleeves and pistons,take a 466 sleeve and have the o ring groove copied onto the 504 sleeve and as i recall you have to shorten them a touch.
wrist pin is the same size and in the same location and it will make 540ci.
DT466
07-10-2007 19:52:49
 Re: stroking a 466 in reply to minnesota red, 07-08-2007 19:48:20
Hey thanks I will check into that and see if I can't find myself a set of those.
minnesota red
07-10-2007 21:58:45
 Re: stroking a 466 in reply to DT466, 07-10-2007 19:52:49
not a problem.
