Piston rod length
ken
05-17-2002 22:05:05
I'm adding 1 inch of stroke to my G crankshaft, and was looking for info on what lenght the rods need to be.If anyone has done this with a .250 overbore using D8 cat pistons I would like to hear how it works.I have seen a couple running this but have no info on rod lenght.Maybe ther is a better setup, I'm open to ideas.
john
05-19-2002 19:49:48
 Re: piston rod length in reply to ken, 05-17-2002 22:05:05
I have never heard of the d8 cat pistons in a g...but...my cuz has a G that has 8" of stroke, and has .250 custom made pistons, and runs 75hp
John
lynn
05-19-2002 17:17:06
ken..cat d8 pistons are 5.750..d9 are 6.250 which are .125 over stock g..have to bush up wrist pins..did a 1 inch g over winter with 60 rods and .125 over g pistons..head worked on with big valves and porting and milled down to swirl..cut pistons off to get 10:1 compression..made 71 hp..lynn
JOhn
05-19-2002 19:57:01
 Re: Re: piston rod length in reply to lynn, 05-19-2002 17:17:06
hey lynn, what size of cat dozer has around a 5.250 piston in it...can be a little over...but not much. Can be another type of motor, but I need a set. Thanks
John
hey, don't you have another g?
JOhn
05-19-2002 19:56:48
John
lynn
05-21-2002 17:28:43
 Re: Re: Re: piston rod length in reply to JOhn, 05-19-2002 19:56:48
John..i looked in my old cat book its 25 years old and the nearest is 5.4..its out of a 3406..i think cat have redone their engines since i messed with them 15 years ago..the old cummins are 5.5..i pull an unstyled a but have helped 2 friends on 5 or 6 g's..lynn
John
05-22-2002 05:19:13
 Re: Re: Re: Re: piston rod length in reply to lynn, 05-21-2002 17:28:43
What does your unstyled A have for horse?
Thanks,
John
(just out of curiosity)
lynn
05-22-2002 17:33:12
 Re: Re: Re: Re: Re: piston rod length in reply to John, 05-22-2002 05:19:13
John..its runs 72 hp..all are checked at 535 rpm on the dyno..5 7/8 x 8 3/8..9.5:1..this figures .159 hp per cubic inch..the g we did over the wintere made .145.. the a's and g's i've done with high compression make between .140 and .150..had a cam ground and degreed when i installed might have made some differance or everything just worked better to make the differance..lynn
ken
05-19-2002 19:50:00
Thanks for the info i was told wrong on the cat piston size.I hate to ask so many questions but nobody around here knows much about stroking cranks including me. If you move the rod journal back 1 inch it,s going to push the piston 1 inch further up and 1 inch further back so are you adding 1 inch or 2 inches of stroke. Any info would be helpful.
Will
05-18-2002 19:47:04
The e-mail address still won't work, Try again
john
05-19-2002 09:04:22
 Re: Re: piston rod length in reply to Will, 05-18-2002 19:47:04
just post it
ken
05-18-2002 20:25:06
dont know what else to try,cant see what is wrong,but thanks for trying anyway.
Will
05-18-2002 08:30:59
Ken, I tryed to e-mail you but it got returned,is your e-mail address correct. Will
