hot farm tractor
ihjerm
07-03-2007 06:35:06
do you think a stock rear end would hold up to a 466 cubic inch hot farm class??? if not what would need to be done??? trying to get enough info as possible thanks jeremy
pullerman
07-05-2007 13:50:56
 Re: hot farm tractor in reply to ihjerm, 07-03-2007 06:35:06
You should put the 466 in the 1466. We have one that weighs only 10,000lbs with driver. There is a few things to do to get it here but it is easy. And also you should try to run a double disk clutch with a good torque. We found out the hard way.
red hot
07-03-2007 11:52:48
yes either will hold but 1466 will be pretty heavy. find a 706 rear and bolt it to it
ihjerm
07-03-2007 09:22:11
sorry not sure either a 1206 or 1466.most likely the 1466 don't want to destroy the 1206. thanks jeremy
AW Puller
07-03-2007 06:50:05
What are you putting it in?? There is a big difference between a 460 and a 1566!
