Advantage of a cut tire?
BlakeG
07-01-2007 20:10:53
What is gained by having cut tires? im from minnesota, so whats the going price around here for a set of 16.9-38 firestones that are hand cut that need some freshing?
buickanddeere
07-01-2007 21:45:16
 Re: Advantage of a cut tire? in reply to BlakeG, 07-01-2007 20:10:53
Tread bars bend over less when pulling on hard clay or concrete. The sharp leading edge of the tread bar stays biting into the track. On a loose sand or limestone track, full height 45 degree bars often work well.
davpal
07-01-2007 20:42:14
They don't dig up as much of the track so less dirt gets piled up in front of the sled and it makes the sled easier to pull.
dds-inc
07-01-2007 20:37:17
SOme people run nearly bald tires. They don't work as well as cut tires. Cut tires are angled so that they really bite the ground like saw teeth.
