H roller rocker questions.
pullerman
07-01-2007 17:23:01
Guys i got a couple questions on this. first what would good springs to use if i go with 1.9 rockers and i can't find a place that makes roller rockers with diffrent ratios like 1.9 on exhaust and 1.7 on intake. its just accross the bord 1.7 or 1.9. so if i could get some specs on a spring setup for a diffrent intake and exhaust lift that would be great. Im camed bored and have alot of head work done and i will be running stock revs most of the time and some high revs every once in a while. Well guys thanks again for the help.
puller man
07-02-2007 08:24:46
 Re: H roller rocker questions. in reply to pullerman, 07-01-2007 17:23:01
Do you know what type of valve springs i should use or anybody that could help me with them
Drew
07-01-2007 18:34:57
You can mix the Murphys rockers 1.9:1 on intake and 1.7:1 on exhaust.
