Stroker crank
puller2
07-01-2007 10:59:28
Can you have a crank that is stroked offset ground to add a little more stroke to it. I have a 7 inch crank with 2.5 journals and I want to go with a 2.25 journal and a little more stroke on this next rebuild. I don't want to do a whole new crank if I don't have to, but wasn't sure if that could be done.
Jon 473
07-02-2007 07:57:50
 Re: Stroker crank in reply to puller2, 07-01-2007 10:59:28
Unless you add metal to the crank you are not going to be pushing the piston any farther up the bore, are you?
yes he is
07-02-2007 10:30:27
 Re: Stroker crank in reply to Jon 473, 07-02-2007 07:57:50
He said to OFFSET grind the crank. This will work, but is a foolish way to do it. What tractor is this in?
puller2
07-03-2007 10:27:14
 Re: Stroker crank in reply to yes he is, 07-02-2007 10:30:27
Why is it foolish. This is in a Case900 7.5 is pretty much max anyways. I am at 7 now, with a 2.5 in. journal which is huge compared to most tractors out there. I am having a new set of rods made and figured why not go out to 7.25 or 7.5 while I am doing it. 2 in journals are doable in this tractor.
life of riley
07-01-2007 13:08:50
you can definitely offset grind it. you won't gain the whole 1/4" but you'll be close.
