crankcase
kendak
06-30-2007 16:01:21
Need another opinion please ...have knocked out back of crankcase on JD 37 "A"for 9.25 stroke ...do I run trans & motor oil together or fab. covers for the slots in case ..kinda leaning to letting oil run together as I had friend with a "G" that had some of the screws that held his pans in place come loose & get into trans. gears...thanks for help...Kent
Big Jugs
07-01-2007 14:16:20
 Re: crankcase in reply to kendak, 06-30-2007 16:01:21
I would go with the pans!!! Look into your transmission case sometime and see all the fine filings from the gears meshing together! You wont have any problems with clearance with the pans....we bolted ours in.
GPULLER
07-02-2007 06:21:30
 Re: crankcase in reply to Big Jugs, 07-01-2007 14:16:20
Jugs
How's that little old A been running? Been out to any pulls?
